SFP-10g-SR-S Compatibility with Meraki Switches
fdharmawan
Level 4
Level 4
Hi Guys,
Currently I am planning to refresh my network to Meraki. My current deployment is using Cisco 3850 and using SFP-10g-SR-S for the SFP. I did some googling, the Meraki SFP has kind of different code on their SFP, like MA-SFP-1GB-SX and MA-SFP-10GB-SR.
My question is, will my current SFP (SFP-10g-SR-S) compatible with the Meraki switches? I know that Meraki is owned by Cisco as well, but well you know, maybe there are some limitations that I do not aware of. Thank you.
5 Replies 5
marce1000
  - I don't know if they have included Meraki already in : Cisco Optics-to-Device Compatibility Matrix
    You may try  it.
    Consider asking in https://community.meraki.com/t5/Switching/bd-p/switching too ,
 M.
Hi Marce,
Tried to asked there as well. Thank you for your answers.
marce1000
 - Also found  : https://community.meraki.com/t5/Switching/Meraki-SFp-Compatibilty/m-p/36528/highlight/true#M3088
  M.
@fdharmawan hi, i have tried the 1G SFP once in the meraki.  but not 10G. you can try it connecting to device and check if that is displaying in the dashboard. also make sure you have latest recommended OS in the device.
Good luck
KB
Thank you Kasun, will try. Hopefully it will be detected.
