12-21-2022 09:19 PM
Please is SG220 with MGBSX1 sfp compatible with WS-C3750X using a GLC-SX-MM sfp?
Solved! Go to Solution.
12-21-2022 10:33 PM
if you planning to interconnect those switches using fiber with those SFPs, yes you can do that.
12-21-2022 10:33 PM
12-21-2022 10:52 PM
How are you able to know this?
12-22-2022 06:40 AM
Because both the MGBSX1 and GLC-SX-MM are 1000BASE-SX compatible transceivers. The benefits of standards.
12-21-2022 11:08 PM
both SFPs are multimode and compatible with given switches. make sure distance between switches below 500m.
