sh interface status vs sh interface summary
Aladdin0z
Hello ,
why i dont see all the interfaces when usinf # sh int status ,
like for example the TenG interfaces and the sfp slots ,
here is the output of # sh int summary
GigabitEthernet1/0/20 0 0 0 0 0 0 0 0 0
GigabitEthernet1/0/21 0 0 0 0 0 0 0 0 0
GigabitEthernet1/0/22 0 0 0 0 0 0 0 0 0
* GigabitEthernet1/0/23 0 0 0 0 0 0 15000 24 0
* GigabitEthernet1/0/24 0 0 0 0 0 0 0 0 0
GigabitEthernet1/1/1 0 0 0 0 0 0 0 0 0
GigabitEthernet1/1/2 0 0 0 0 0 0 0 0 0
GigabitEthernet1/1/3 0 0 0 0 0 0 0 0 0
GigabitEthernet1/1/4 0 0 0 0 0 0 0 0 0
Te1/1/1 0 0 0 0 0 0 0 0 0
Te1/1/2 0 0 0 0 0 0 0 0 0
Te1/1/3 0 0 0 0 0 0 0 0 0
Te1/1/4 0 0 0 0 0 0 0 0 0
* GigabitEthernet2/0/1 0 0 0 0 2560000 748 94531000 11071 0
* GigabitEthernet2/0/2 0 0 0 0 1525000 188 45809000 5216 0
environment : 2 x C9200-24P (stacked)
19 Replies 19
Aladdin0z
Switch with  32 Ports
 Model > C9200-24P
SW Image >  CAT9K_LITE_IOSXE
I need a bit more specific, sorry.  C9200-24P ?
C9200-24P-4G
C9200-24P-4X -  I believe is 4X
Aladdin0z
the model number i exactly C9200-24P
Ok @Aladdin0z
and you have module card on the right ? NM-4X ?
Best regards
OK, I got it, thank you.
Those switch is suppose to support modules.
C9200-24P
Stackable 24x1G PoE+ ports; 4x1G and 4x10G network modules for uplink ports; 2 power supply slots; 2 field-replaceable fans; supports StackWise-160.
Those interface you see is related to modules.
GigabitEthernet2/1/1 unassigned YES unset down down #these interfaces here are not shown in sh int status
GigabitEthernet2/1/2 unassigned YES unset down down
GigabitEthernet2/1/3 unassigned YES unset down down
GigabitEthernet2/1/4 unassigned YES unset down down
Te2/1/1 unassigned YES unset down down #these interfaces here are not shown in sh int status
Te2/1/2 unassigned YES unset down down
Te2/1/3 unassigned YES unset down down
Te2/1/4 unassigned YES unset down down
But, probably to optimize coding, Cisco does not remove all the interface from the device. But they ask to Disregard some interfaces
Table 2. C9300-NM-4G Module
Interface Action
Configure this interface
TenGigabitEthernet1/1/1
Disregard
TenGigabitEthernet1/1/2
Disregard
TenGigabitEthernet1/1/3
Disregard
TenGigabitEthernet1/1/4
Disregard
