Temperature via TL1
shumakov_anton
Hallo.
How can i get temperature of the node 15454 via TL1? I want to put this value to database.
I was used utility getTemp.exe (WIN) for this before.
getTemp.exe (Cisco ONS 15xxx NE Temperature Monitoring Utility 1.0.)
Tom Randstrom
There is not a TL1 command for retrieving the temperature of the node. It is only visible on the shelf's fan tray assembly.
Thats not true. You can scan it via snmp.
