02-04-2002 01:36 PM - edited 03-12-2019 02:18 PM
i'm wondering if anyone out the ris using 3.1(3a) yet? any bug problems?should i bother upgrading to it?
02-06-2002 07:03 PM
CM 3.13a has resolved a bunch of DDTS, so if you are running into any of this bugs, you can upg to 3.1.3a. Pelase checkout the release notes for list of resolved issues:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_1/rel_note/313acmrl.htm#xtocid15
02-07-2002 01:44 AM
Yes we are using it, we've less problems now, if you know what I mean.
02-07-2002 11:53 AM
Upgraded so we could disable the SRS Telephony feature. This was causing problems with some testing we were doing with the phones over our DSL lines. IP Phones were trying to register to the default router as a backup call-manager. With 3a we were able to disable this.
02-07-2002 12:50 PM
Ben,
3.1(3a) has proven very stable so far at several large (and busy) deployments. There are a lot of issues addressed in this version that you may or may not be running into. Our position at TAC is one of recommending the upgrade.
Have a look at the Release Notes for more details on what is new and improved in 3.1(3a)
Victor
