12-05-2005 07:41 AM - edited 03-13-2019 11:26 AM
I am trying to get a 3745 set up as a h.323 gateway to register to the gatekeeper set up on the same router. A show gatekeeper end ,
i see my mcu and video equipment registered.
a debug h225 asn1
does not show any rejection.
not sure what i am missing in the commands.
here is part of the config
gatekeeper
zone local gkbl dickinson-wright.com 10.11.1.240
no shutdown
interface FastEthernet0/1
description Bloomfield_Voice
ip address 10.211.0.1 255.255.0.0
service-policy input QPM_llq100-policyBL_1
service-policy output QPM_llq100-policyBL_1_1
speed 100
full-duplex
h323-gateway voip interface
h323-gateway voip id gkbl ipaddr 10.211.0.1 1719
h323-gateway voip h323-id cgw011a
h323-gateway voip bind srcaddr 10.211.0.1
Attached is the full config
thanks for anny assistance
jeff
12-05-2005 01:06 PM
you are missing the command "gateway" in global config mode.
12-06-2005 11:10 AM
Hi agopala,
I added the gateway in global, i also set the gatekeeper ip to the same ip as the gateway on the fas0/1. still show gateway shows not registered to gatekeeper, and no gateways ghow up in the sh gatekeeper end, only the video end points.
very strange,
thnaks for your ideas
Jeff
12-06-2005 01:41 PM
Is there anyway I can get on your routers? If possible that is great. Otherwise, I want to get a good look at "debug h225 asn1" (please send it to the buffer and then do a show log). Thanks!
12-06-2005 11:34 AM
Hi Agopala,
Got it to register,
I set the gateway to use multicast instead if the fixed ipaddress since i only have 1 gatekeeper to find.
