3745 MGCP won't fail over
hwilms
I have a 3745 witha PRI configured as mgcp 12.3(7)T1
The IP phones will not fail over to SRST when CCM is down. Will IP voice 12.3(7)T1 work or does this have to be a Plus version. I could not find Plus version for 12.3. Some conversations on this forum also lead me to believe there are issues with MGCP and SRST. any help would be appreciated
abdulr
SRST does work with MGCP configured GWY. Can you post your config on the MGCP GWY.
SRST does so work with MGCP.
You need these 2 global commands, besides the fallback config.
ccm-manager fallback-mgcp
call application alternate DEFAULT
On the pots dial-peers, make sure they have 'application mgcpapp' under them. the Destination-pattern will come into play when in fallback (H323) mode.
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.1.30.5
ccm-manager config
controller T1 0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
call application alternate default
mgcp
mgcp call-agent 10.1.30.5 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
call-manager-fallback
secondary-dialtone 9
max-conferences 8
ip source-address 10.1.30.1 port 2000
max-ephones 48
system message primary Cisco SRST-fallback mode
dialplan-pattern 1 856830.... extension-length 4
keepalive 10
access-code pri 9 direct-inward-dial
voicemail 9856830XXXX
Daniel Baum
What version of CallManager is being used?
If 3.3x, you will need to enable SRST in CCMAdmin System / Device Pool / SRST Reference for the Device Pool. By default SRST is disabled.
SRST Reference
From the drop-down list box, choose a survivable remote site telephony (SRST) reference to assign to devices in this device pool. You have the following options available:
Disable--If you choose this option, devices in this device pool will not have SRST reference gateways available to them.
Use Default Gateway--If you choose this option, devices in this device pool use the default gateway for SRST.
Existing SRST references--If you choose an SRST reference from the drop-down list, devices in this device pool will use this SRST reference gateway.
See CCMAdmin System / SRST to add SRST References for the device pool SRST Reference.
In addition see:
Configuring SRS Telephony and MGCP Fallback
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a0080144630.shtml
See the Cisco Feature Navigator II for the Feature to IOS version you need:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Dan
