4305G Lost power during upgrade, now what?
RANDY CARLSON
Upgrading frimware on the 4305G and someone unpluged power. Now it will not boot, it's a brick. Any chance to bring it back to life?
-Randy
Nicolas Fournier
Hi Randy,
The only thing you can try  is to restore the DMP to factory default.
This can be done by keeping  the RESET button on the back of the DMP pressed for at least 10 seconds.  You should hear at least two "beep" in a row when doing so, if you hear  only one it means that the DMP is rebooting but not restoring to  factory default.
It this doesn't help then I'm afraid you have a nice new bookend
Nicolas
