06-19-2003 05:17 AM - edited 03-13-2019 12:25 AM
Is there a way to trans fer a caller to a phone on the side car by just hitting the line of the user you are transfering to.
I mean: Call comes in ---> 1000 you pick up ---> transfer----> then press the button next to ext. on the sidecar -----> transfer. I does not work is there some firmware or option to allow this to happen. And please do not say Attendant Console that is not an option. Legacy PBX and Key systems do it.
06-19-2003 12:06 PM
I hate the 7914, But if you make them speed dials, they will work the way you want. However they will not light up when the person is on the phone.
06-19-2003 12:08 PM
Thx I know that one , but I was hoping one of you developer types had a patch to fix that I guess not. I need the lights.
