7942 phones and the Bogen paging system
nlouie
Hello, we have a Bogen paging system connected via an FXO card to the BE6K and we are getting inconsistent results when we call the paging local.  For some phones it works but other phones it just rings and the paging system never picks up.  What makes the paging system pick up after you call the local?
Manish Gogna
Normally in such issues we start by comparing the settings of the working and non working phones on CUCM ( device page and end user page). If those are consistent then you can check if the issue is being faced by a specific phone model , or phones in a specific device pool or connected to a specific switch. Once all of these are verified then we can take a packet capture from the working and non-working phone to check the signaling with Paging system.
Manish
- Do rate helpful posts -
