About Cisco IP Phone usage without Call Manager
patrick.zhang
I have two Cisco 7960 IP Phone and some Cisco switches and Routers,but I have no Cisco Call Manager software.
Can I do some IP Telephony Lab test without Call Manager?
If yes,how?
Thank you!
18 Replies 18
david.lawrence
Level 3
Level 3
You have a couple of options:
1) Use ITS 2.1 - Cisco IOS Telephony Service.
Supported Routers :Cisco 1751, Cisco 1760, Cisco 2600-XM, Cisco 2650, Cisco 2650-XM, Cisco 2651, Cisco 2691, Cisco 3640, Cisco 3640A, Cisco 3660, Cisco 3725, Cisco 3745.
Supported Phones:Cisco IP Phone 7910, Cisco IP Phone Expansion Module 7914, Cisco IP Conference Station 7935, Cisco IP Phone 7940, Cisco IP Phone 7960, Cisco ATA-186, Cisco ATA-188.
This with not give you all the features of CCM. See link for more info:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide_book09186a0080153d1f.html
2) Get the book Developing Cisco IP Phone Services from Cisco Press.
https://www.amazon.co.uk/exec/obidos/ASIN/1587050609/026-4415890-2862849
The enclosed CD contians CMSIM - Call manager Simulator. Again you will lose some functionality but might help for a lab enviroment.
David
kshalavin
Yes, You can.
Look for IOS Telephony Service (ITS) at Cisco site. Configure this feature at Cisco Router.
You may need to change Software at Your Router, and You need also to buy Feature License to use ITS legal.
See URL below:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_feature_guide09186a0080128fb3.html
I'm setting up a ITS router-Cisco3640.When I set up ITS GUI,input "ephone 2" command,error message"ephone tag 2 exceeds max-ephones 0 ",what it mean?
Try to add command "max-ephones " command under telephony-service configuration menu.
Look below for my lab config:
telephony-service
load 7910 P00403020204
load 7960-7940 P00303020204
ip source-address 20.206.1.4 port 2000
max-ephones 8
max-dn 8
max-conferences 2
moh eagle2.ULAW.wav
time-format 24
date-format dd-mm-yy
admin-username admin
admin-password admin
dn-webedit
time-webedit
Good Luck.
Dear support,
Thanks for your help!
I have connectted the ITS Router(Cisco3640) and one Cisco7960 to a Cat3524 switch,follows is configuration of the ITS router.When I powered on the Cisco7960,it always be in "config ip address" or "open 10.130.0.106" status,10.130.0.106 is the ip address of ITS router.I don't know wh
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
boot system tftp c3640-is-mz.122-15.T.bin 10.130.0.21
logging queue-limit 100
enable password unison
ip subnet-zero
no ip domain lookup
ip dhcp pool pool1
network 10.130.0.0 255.255.255.0
option 150 ip 10.130.0.106
default-router 10.130.0.106
no voice hpi capture buffer
no voice hpi capture destination
mta receive maximum-recipients 0
partition flash 2 8 8
interface Ethernet0/0
no ip address
shutdown
half-duplex
interface FastEthernet1/0
ip address 10.130.0.106 255.255.255.0
ip helper-address 10.130.0.249
duplex auto
speed auto
interface TokenRing1/0
no ip address
shutdown
ring-speed 16
ip http server
ip http path flash:
ip classless
tftp-server flash:1:P00303020209.bin
call rsvp-sync
mgcp profile default
dial-peer cor custom
telephony-service
load 7960-7940 P00303020209
max-ephones 10
ip source-address 10.130.0.106 port 2000
web admin system name patrick password unison
dn-webedit
time-webedit
ephone 1
username "unison" password unison
line con 0
line aux 0
line vty 0 4
password unison
login
end
Maybe you are missing the command
tftp-server flash:SEPDEFAULT.cnf
according to the example at
http://www.cisco.com/en/US/partner/tech/tk652/tk701/technologies_configuration_example09186a00800ffdcc.shtml
regards,
Yanna
Thank you!
But Wher can I get the SEPDEFAULT.cnf file?
I didn't find it in the ITS2.1.0.2 ZIPfile.
The answer is below:
When Cisco IOS Telephony Service is configured, the Cisco IP phones receive initial configuration information and phone firmware from the TFTP server. In most cases, the Cisco IP phones obtain the IP address of their TFTP server with the Dynamic Host Configuration Protocol (DHCP) option 150 command. For Cisco IOS Telephony Service operation, the TFTP server address obtained by the Cisco IP phones should point at the Cisco IOS Telephony Service router IP address. The Cisco IP phones attempt to transfer a configuration file called SEPDEFAULT.cnf. This file is automatically generated by the Cisco IOS Telephony Service router through the ip source-address command and placed in the router's Flash memory. The SEPDEFAULT.cnf file contains the IP address that the phones use to register for service, using the Skinny Client Control Protocol (SCCP). This IP address should correspond to a valid Cisco IOS Telephony Service router IP address (and may be the same as the router TFTP server address). Access to the SEPDEFAULT.cnf file must be granted through the tftp-server command on the router.
Patrick,
check flash files at your router. It should look like this (if You have only one IP phone You need only one P00???.bin file, and in Your case you may not need eagle2.ULAW.wav file):
ITS#sh fla
System flash directory:
File Length Name/status
1 14097360 c2600-is-mz.122-11.T.bin
2 55 SEPDEFAULT.cnf
3 250 XMLDefault.cnf.xml
4 405626 P00303020204.bin
5 367838 P00403020204.bin
6 18717 eagle2.ULAW.wav
[14890240 bytes used, 1362688 available, 16252928 total]
16384K bytes of processor board System flash (Read/Write)
Don't forget to put phones Load images, and configuration files.
A good idea to download from Cisco site ITS file with all required files at put needed files to flash memory.
Next one, I haven't seen in Your config command like:
tftp-server flash:XMLDefault.cnf.xml
Last, You have only entered "ephone 1" and there is no "ephone-dn" command
In Your case it should be look like:
ephone 1
mac-address
button 1:1
ephone-dn 1
number 1234
name unison
hold-alert 15 originator
Try to do it.
Good Luck.
Thank you!
But.......
I have add the configuration you asked,and the 7960 still in "configuring IP".
I have checked the "Network" in the 7960,I'm sure it got the ip address from DHCP(ITS router),and it's firmware has downloaded.May be the config file it can't download from DHCP server.
I have inputed the command "IP source-address port 2000",but no SEPDefault.cnf file created.
No dial tone in the "ear" of 7960.
Current configuration : 1515 bytes
version 12.2
hostname Router
ip subnet-zero
no ip domain lookup
ip dhcp pool pool1
no ip address
shutdown
half-duplex
duplex auto
speed auto
no ip address
shutdown
ring-speed 16
ip http server
ip http path flash:
ip classless
tftp-server flash:1:XMLDefault.cnf.xml
tftp-server flash:1:SEPDEFAULT.cnf
call rsvp-sync
telephony-service
max-ephones 10
max-dn 8
max-conferences 2
time-format 24
web admin system name admin password admin
dn-webedit
time-webedit
ephone-dn 1
number 1234
name unison
ephone 1
mac-address 0009.B7DA.0C6E
button 1:1
line con 0
line aux 0
line vty 0 4
password unison
login
end
Router#sh flash
System flash directory, partition 1:
1 6165696 c3640-i-mz.122-12.bin
2 371312 P00303020209.bin
4 4001 ephone-admin.html
5 2240 telephony-service.html
6 35138 normal-user.html
7 1720 XMLDefault.cnf
8 1720 XMLDefault.cnf.xml
[6611436 bytes used, 1777172 available, 8388608 total]
8192K bytes of processor board System flash (Read/Write)
System flash directory, partition 2:
No files in System flash
[0 bytes used, 8388608 available, 8388608 total]
I've made now a test - I deleted file SEPDefault.cnf from flash, squeeze flash.
After that I go to telephony-service configuration menu and do next:
1. no IP source-address port 2000
2. reset all
3. IP source-address port 2000
After that I got again file SEPDefault at flash memory.
No,I can't get this file.
show flash
Delete----reset all----Add,
sh flash
Nothing changed.
Debug TFTP
Finished system:/its/XMLDefault7960.cnf.xml, time 00:00:00 for process 146
05:29:02: TFTP: Server request for port 51795, socket_id 0x633A078C for process 146
05:29:02: TFTP: read request from host 10.130.0.1(51795) via FastEthernet1/0
05:29:02: TFTP: Looking for OS79XX.TXT
05:29:02: TFTP: Sending error 1 No such file
05:29:02: TFTP: Server request for port 51796, socket_id 0x633A078C for process 146
05:29:02: TFTP: read request from host 10.130.0.1(51796) via FastEthernet1/0
05:29:02: TFTP: Looking for SEP0009B7DA0C6E.cnf.xml
05:29:02: TFTP: Opened system:/its/XMLDefault7960.cnf.xml, fd 0, size 0 for process 146
05:29:02: TFTP: Sending block 1 (retry 0), socket_id 0x633A078C
05:29:02: TFTP: Received ACK for block 1, socket_id 0x633A078C
05:29:02: TFTP: Finished system:/its/XMLDefault7960.cnf.xml, time 00:00:00 for process 146
05:29:17: TFTP: Server request for port 51993, socket_id 0x633A078C for process 146
05:29:17: TFTP: read request from host 10.130.0.3(51993) via FastEthernet1/0
05:29:17: TFTP: Looking for OS79XX.TXT
05:29:17: TFTP: Sending error 1 No such file
05:29:17: TFTP: Server request for port 51994, socket_id 0x633A078C for process 146
05:29:17: TFTP: read request from host 10.130.0.3(51994) via FastEthernet1/0
05:29:17: TFTP: Looking for SEP0009B7DA0C03.cnf.xml
05:29:17: TFTP: Opened system:/its/XMLDefault7960.cnf.xml, fd 0, size 0 for process 146
05:29:17: TFTP: Sending block 1 (retry 0), socket_id 0x633A078C
05:29:17: TFTP: Received ACK for block 1, socket_id 0x633A078C
05:29:17: TFTP: Finished system:/its/XMLDefault7960.cnf.xml, time 00:00:00 for
Patrick.
Look below an information about requirements for ITS versions 2.1 and 2.0, and check what You have http://www.cisco.com/cgi-bin/tablebuild.pl/ip-iostsp
It could be a problem with IOS and ITS version mismatch.
Regards.
