08-26-2009 03:11 PM - edited 03-13-2019 06:37 PM
I have a CallManager version 4.0(2a), I need to add the firmware for IP Phone 7911 and 7937G, but are not listed on Firmware Load Information option, I already have the files on TFTPPath but what is missing??
Thanks for your help.
JC Arias
08-26-2009 03:27 PM
You are missing the Device Pack files.
08-26-2009 03:32 PM
Thanks for your answer Paolo, this is my first time procedure, could please guide me a little more?? Those Device Pack files can be downloaded from Cisco site??
I search for information this, but I can't find it.
Thanks again.
08-26-2009 04:11 PM
I think I found the procedure, thanks
08-26-2009 06:12 PM
Actually there is no support for 7937 on your version
Registering the Cisco Unified IP Conference Station with Cisco Unified Communications Manager
To register the Cisco Unified IP Conference Station 7937G with Cisco Unified Communications Manager releases 7.0, 6.1, and 6.0 and Cisco Unified CallManager releases 5.1, 4.3, 4.2, and 4.1, follow these steps:
for 7911
Supported CallManager Versions
java
if this helps, please rate
08-27-2009 06:27 AM
Thanks for your time Jaime, I'll work on it.
