10-09-2002 11:56 AM - edited 03-12-2019 09:06 PM
I am configuring an ATA 186 with the web browser and there are 2 field that I don't know what should I set. They are "Use H323 ID:" and "Gateway IP".
I would be very gratefull If somebody could tell me what to set in those fileds.
Regards,,
10-10-2002 01:02 AM
you use H323 ID if you have a gatekeeper and want to register the ATA with the gatekeeper. This might be optional.
The gateway IP is the address of the media gateway (like Cisco 2600/36XX/53XX) that connects to the POTS. This is the address where you terminate calls.
hope it helped
10-10-2002 02:50 PM
# GateWay: alphanumeric string (31 characters max) -- gateway ip (if
# gatekeeper is not used for routing call)
# IVR Access Code <11>
and
# GkId: alphanumeric string (31 characters max) -- gatekeeper zone id
# (default is '.').
# IVR Access Code <91>
