ATA CallWaitTone info?
marckalex
Hi all,
How it is possible to change the time of repetition of the CallWaitTone in the ATA186/188 SCCP + CCME?
Ten second of time is unacceptable!
Tnx so much.
Marck
6 Replies 6
marinaibm
Level 4
Level 4
SigTimer parameter controls various timeout values for the ATA.
Bit 0-7
Call waiting period—The period between each burst of call-waiting tone.
Range: 0 to 255 in 0.1 seconds
Default: 100 (0x64=100 seconds)
Re:
Yes.
I have seen this parameter and also I have modified with 0x000000FF
But the ATA do not give no result, always to ten second remain.
ideas?
by Marck
I just tried it myself and with 0x000000FF it increases the timeout to about 25 seconds.. What software version are you running?
Re:
1760-V CCME 3.2
IOS 12.3.11T3
ATA186-I1-1P-CH1-A
V3.1.0 ATASCCP Build040211A
Tnx so much.
Marck
Actually you are right. I tried it with an ATA connected to a callmanager.
When i put it on calmanager express the parameter doesn't make any difference anymore..
Re:
Which it can be the cause of that?
Some idea of alternative solution?
