01-30-2006 03:50 AM - edited 03-15-2019 04:02 AM
My customer has an analog intercom system at their front gate. When the button is pressed the call rings an extension in CCM. I have this working - the analog intercom is connected via an ATA & I use a blank translation pattern to simulate PLAR functionality.
Now when the gate intercom button is pressed an internal extension rings.
My problem being that when my internal extension hangs up, the analog intercom is not closing the line & continues to dial the internal extension.
Now the "supervisory disconnect" issue affects FXO & my ATA is FXS - does this mean that the problem is with the remote analog intercom device ?
Is there any solution I can provide from the CCM side (4.1(3)sr2) ?
TIA.
02-03-2006 07:24 AM
02-22-2007 03:05 AM
Hi there,
Did you manage to resolve this issue? Its just that I am seeing the same thing. I have tried different ATA's, H323 and SCCP, CCM ver 4.02 and 4.1.3sr3 but always the same thing: when the IP phone disconnects the ATA continues to keep the line open.
06-19-2008 02:12 PM
I am having issues with the same thing...my intercom which is an analouge device does not hang up...
Any ideas...
HIfazal
06-24-2008 01:07 PM
I read in another post that reversing the polarity solved the problem.
Polarity: You can control line polarity of the Cisco ATA FXS ports when a call is connected or disconnected by configuring the Polarity bitmap parameter as follows:
â¢Bit 0: CALLER_CONNECT_POLARITY. Polarity to use when the Cisco ATA is the caller and the call is connected.
-0 =Use forward polarity (Default)
-1 =Use reverse polarity
â¢Bit 1: CALLER_DISCONNECT_POLARITY. Polarity to use when the Cisco ATA is the caller and the call is disconnected.
â¢Bit 2: CALLEE_CONNECT_POLARITY. Polarity to use when the Cisco ATA is the callee and the call is connected.
â¢Bit 3: CALLEE_DISCONNECT_POLARITY. Polarity to use when the Cisco ATA is the callee and the call is disconnected.
Note: Bits 4-31 are reserved.
Default: 0x00000000
Voice Configuration Menu Access Code: 304
Four our gate, setting bit 1 to 1 solved our problems:
In Binary: 01000000000000000000000000000000
In Hex: 0x40000000
