09-25-2007 05:27 PM - edited 03-13-2019 04:27 PM
I have a user who uses AC to provide busy/free status of lines on their 4.2.3 box. They don't use call control. AC has recently started grabbing focus on incoming calls which is annoying for the user as they are working in other programs when this happens. The user and their IT department claim that nothing has been changed on the PC, and we have made no changes on this user's CM profile. Any thoughts as to what may have changed/how to change it back?
Our last choice would be some software to force the open window to stay on top but since this was what was happening before, there should be some way of returning to that.
Solved! Go to Solution.
09-26-2007 04:23 AM
Hi Joe,
You can use this method to enable / disable "Pop to Top"
Note: To toggle the pop-to-top feature on and off, press Alt + P.
From this doc;
Hope this helps!
Rob
09-26-2007 04:23 AM
Hi Joe,
From this doc;
Hope this helps!
Rob
09-26-2007 02:48 PM
Hmm looks like I should have RTFM. Thanks for that, I'd looked but hadn't seen it. That should do the trick.
09-27-2007 04:25 AM
Hi Joe,
I wouldn't feel too bad here :) I always find that the most pertinant facts are almost always the hardest to find with this documentation! This is why I find these forums so helpful. Usually, someone else has encountered the unexpected and unexplained.
Take care and thanks,
Rob
