Barge in and Flush input buffer
mariusst
In a menu the "barge in" and "flush input buffer" is both set to "yes".
When a caller phone in they cannot interrupted the prompt but any keys they press are remembered and as soon as the prompt ends they are routed to that option. How do I change this that input from the caller are only excepted after the prompt ends.
venkasub
Level 4
Level 4
You need to set the Barge-In to "NO" in Menu Step Properties->Prompt Tab, so that the prompt must complete playback before the caller can respond.
Following is from Cisco CRA Editor Step Reference Guide for Menu Step
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_3_1/english/admn_app/step_ref/media.ht
m#42670
Barge In
If Yes, the caller can interrupt the prompt.
If No, the prompt must complete playback before the caller can respond.
Hope it helps. Try this and let me know the result.
Venkat
yogeswar
Level 4
Level 4
The editor step refernce guide should explain you clearly about the difference in "Barge in" and "flush input buffer" settings in Menu step.
If you donot want the customer to interrupt the prompt in between, you need to set barge in as "YES".
Barge in - If Yes, the caller can interrupt the prompt.
Flush Input Buffer - If Yes, the system erases previously entered input
before capturing caller input.
If No, the system does not erase previously
entered input before capturing caller input.
For more information check out the Editor step reference guide
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_3_5/english/admn_app/step.pdf - Pg.No: 7-48.
Yogi
