01-24-2006 01:30 AM - edited 03-13-2019 11:55 AM
http://info.connect.com.au/docs/routing/general/multi-faq.shtml
((How do I configure BGP so that bad things don't happen?))
Does the command "ip as-path access-list 1 permit ^$" from the link above, stand for a null path (^$) ?
01-24-2006 01:51 AM
Yes.
The regular expression ^$ matches the empty string.
This is useful when matching on prefixes that are locally generated within an AS. They will carry an empty AS-PATH until they leave the AS. Therefore, ^$ can be used within an as-path access-list to match on locally generated routes ...
Hope that helps - pls do rate posts that help.
Paresh
01-24-2006 03:22 AM
basically this allows to sort out those routes learned from another AS. It is the easiest and most flexible way of preventing to become transit AS between two ISPs for a customer.
The statement would allow only those routes to be announced, which are locally originated within the customer AS.
Hope this helps! Please rate all posts.
Regards, Martin
