Bluetooth headset with Cisco IP phone
Asad Raza
Hello all,
A client is trying to connect a Plantronics Savi WT/1T bluetooth headset with a Cisco 7940 IP phone and it seems to work just fine when he receives a call and presses the "headset" button at the bottom of the phone. However, he wants to be able to walk outside his office and be able to receive calls by pressing the button on his bluetooth headset however the button is not responsive. Is there a way to configure this? I feel as though the button on the headset and the headset button on the IP phone would somehow have to be synchronized but I don't see how that is possible. Has anyone configured a bluetooth headset with a Cisco IP phone and have this functionality work?
Thanks for your help in advance.
Rob Huffman
Hi Asad,
For this to work you would need a couple of things;
- a phone that supports HHC (headset hookswitch control) such as
Cisco 7942G, 7962G, 7945G, 7965G, 7975G
- the proper cable from Plantronics to work with the Savi this would
connect to the Aux port on the base of the phone and works in conjunction
with the HHC (enabled) funtion on the phone config in CUCM
- minimum CUCM 4.1(3)sr7
I can't find the model of Savi you linked but if you could check the exact model
number/name we could provide further details.
Cheers!
Rob
8 Replies 8
Rob Huffman
Hi Asad,
Cheers!
Rob
Hi Rob,
Thanks for your help! The strange thing is, I can't seem to find that particular model anywhere either, yet, the customer insists that, that is exactly what the product box reads. In any case, I have provided the user with the necessary information, and once they've purchased the APC-4 HHC adapter, I'll configure it for them. Oh, and they're running CCM 4.2(3)sr2b, so hopefully that will be good enough.
Thanks again your help!
Rob Huffman
Hi Asad,
You are most welcome my friend!
Don't forget the IP phone requirements
So you will need to replace the 7940 for this to work.
We did run HHC with 4.2(3) but it was 4.2(3)sr3 so if you have any problems
you may to need to upgrade. You can check by looking at a 7942/62 etc. phone
config page in CUCM and looking for the "headset hookswitch control" setting
to see if it's available.
Cheers!
Rob
Hi Rob,
Just to be perfectly clear, there are absolutely no bluetooth headsets from any vendor that would work with a Cisco 7940 phone whatsoever? And to get any bluetooth headset (for Cisco phones) to work, we would have to have one of the models you mentioned earlier and CCM version 4.1(23) or above. Am I getting this right?
Thanks agian.. you're the man!
Best Regards,
Asad
Hi Asad,
you could use a lifter like the HL10 straight plug (http://www.plantronics.com/us/product/hl10-savi). Works fine for me.
Best regards,
Peter
Rob Huffman
Hi Asad,
First off, you are most welcome my friend
As you have discovered, the one feature that won't work in your current
setup with the 7940 is the ability to answer calls with the Headset while
away from the phone. The 7940/60 series of phones do not have the
Headset Hookswitch Control (HHC) setting available in any version of
CUCM. The HHC setting is the main requirement for answering calls
with the headset so without it you are not going to be able to make this
work for your user
To check your CUCM version requirements try to Add a new 7942 and under
the Product Specific Config section on the phone config page look for;
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Rob Huffman
Hey Peter,
Good point my friend +5
I hadn't thought about the "lifter" kit.
Cheers!
Rob
Hi Peter and Rob,
I had seen the 'lifter' on several websites but I had no idea what it was for, but now that you guys have mentioned it, I checked out a video on Youtube and found out how it works, and it sounds pretty good for people with IP phones that are not HHC capable. I will recomment this to my client as an alternative. Thank you both for your help - it is much appreciated!
Best Regards,
Asad
