BRI configuration to BT line point-2-point or point-2-multipoint
m.murad
I have a Basic rate ISDN line provided by BT which is actually two ISDN2e boxes tied together to give 4 channels instead of the usual 2 and it has 9 DDI lines. The problem is now that the siganlling on this line according to BT is set to T.Ref (point to point) where as a standard ISDN2e is set to ST.Ref (point to multipoint). Now I can get my VIC2-2BRI-NT/TE installed in a NM-HD-2V to work on a standard ISDN2e for outgoing calls but I can not get it to work on the 4 channel BRI can anyone advise on how I would configure it to work on this line?
mfernandez
Hi.
I think you refer to ISDN-PBX from Euro-ISDN.
Try in both BRI interfaces:
isdn incoming-voice voice
isdn point-to-point-setup
isdn static-tei 0
Regards.
Miguel.
mfernandez
Hi.
isdn static-tei 0
Regards.
Miguel.
