Broadcast Voice/Audio to Multiple IP Phone
pengkeong.fong
Dear all,
How can i broadcast audio stream(announcement) to multiple ip phones?
Are there any available software that can integrate with Call manager that provides this feature?
Thank you
trailman73
Level 4
Level 4
Try Berbee Informacast. They have a good product, and you can run it on Unity, I would not put it on CCM. They have good techs and it is reasonable.
www.berbee.com
Geoff
Dear Geoff,
Thanks for the info
You can also try SA-Announce from Syn-Apps.
It supports cm 3.1-3.3.
Easy setup and administration.
www.syn-apps.net
gshonting
Build a simple service using RTPMRX: to receive a muticast steam.
check out- http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide09186a008011ab23.html#xtocid29
I have used this in a demo by enabling multicast Music-on-hold and setting up a service to listen to the multicast MOH. This may or may not be supported depending on what version of CM you have. I think the test system I used was 3.2.2c but it is more dependant on what phone load you use, as it is the xml parser in teh phone that needs to support the RTPMRX tag.
