Bypass SSO for Unity PCA
JasunKAR
Howdy!  Anyone know of a clean way to bypass SSO for Unity PCA login?  Many BUs use shared mailboxes that do not belong to "people".  I'd like to give them the PCA link and have them log into a mailbox to check messages visually.
I know i can go to the admin page and bypass SSO, then login, then put in the PCA (/ciscopca) and it works, but that's not a solution I want to give to our end users as it is very clunky.  I'd like one link to log into PCA bypassing SSO if that is possible.
Not finding much luck in my googles and searches.
Unity 12.5(Su5)
2 Accepted Solutions
Jaime Valencia
AFAIK that's the only option you have once SSO is enabled.
java
if this helps, please rate
Turning on SSO has the effect that all logins is required to use it. From what I know there are no other way to bypass it other than what you already described.
Response Signature
Jaime Valencia
java
Response Signature
JasunKAR
Ah well, worth a shot asking.  I appreciate y'alls time answering!  Have a great day!
