CAD issue Call manager failover
Curtis Fuentes
                    Hi All,
    I have multiple CAD  users getting kicked out of CAD with error code Call Manager failover. We are using CM 8.5 and UCCX 8.5. I am not seeing any issues wuth the call manger and other call complete. What could cause this issue. I have uploaded a picture of the issue.
Thank you
anchoudh
Level 9
Level 9
Hi Curtis,
CM_FAILOVER
Reason Code: 32757
State: Not Ready
The system issues this reason code when the            Unified CM fails over and the agent           is moved to the Not Ready state.
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_9_0/user/guide/UCCX_BK_UE5BE47D_00_uccx-historical-reports-ug_appendix_0111.html
You can check if really the CUCM failover is happening, or network connectivity between the phones and CUCM...etc
Hope this helps.
Anand
Please rate helpful posts !!
I checked RTMT tool and it shows the SDL link went down witch cause the phones to flap between call managers. How can I find out what caused the SDL links to go down ?
Hi Curtis,
Please check the CUCM logs through RTMT tool for the excat reason for failure.
Anand
pls rate helpful posts !!
I checked the log and all it shows is SDL link faild. Does not give a reason.
