ā09-06-2019 02:58 PM
we just installed new 7841 phones and one will not call fwd. When using the soft key and entering a number it gives a dial tone and asks to check the directory?
ā09-06-2019 08:35 PM
Always mention what products you use, and version, and not just your problem or what you want.
What is the call control for this? And what troubleshooting have you done?
By the "check your directory" message, I'd assume it's CUCM, in which case you need to fix your call forwarding CSS to allow the call.
ā06-13-2022 02:49 PM
What do I need a configure in laymans terms. I'm trying to configure call fowarding on a cisco ip phone model 7800. Help please
ā09-08-2019 11:45 PM
Check what is your DN's CSS for that phone. Is it same as other phones ? Are you using correct route pattern ? Use CUCM's DNA to check if you can dial out the call forward number successfully using that DN.
