CUCM First call routing lookups components, RP or RP
KY_
Level 4
Level 4
Hi All
Which component cucm will looks first when the call placed on the cucm registred ip phone to pstn calls ? translation pattern or Route pattern I could not find exact any documents for this can you please someone also provide me offical cisco documantation for this?
Thank you, Roger . I wrote incorrect information .
I agree with you. Translation pattern used for outgoing call too.
Regarding to question from topicstarter:
Translated Pattern used for digit manipulation.
Route Pattern used for making call.
First - digit manipulation , then route call.
"CUCM uses translation patterns to manipulate digits before forwarding a call ... "  from https://www.ciscopress.com/articles/article.asp?p=1745737&seqNum=3
i beg your pardon all - for yesterday incorrect message
BR Oleksandr
There are no priority between different configuration elements in CM when number analysis is evaluating what to use to route a call. All of these are in the same table more or less. What influence the order is the best match and then order of partitions within the calling search space.
Response Signature
Hi ,
Translations Patterns are used first for incoming calls to CUCM.
You can easy check it whithout documentation )
P.S. for outgoing calls translation patterns not used
BR Oleksandr
I challenge both of your statements. Translation patterns can definitely be used for outbound calls. We do that for 0 (zero) prefix dial to convert to +E.164. Also for inbound calls there are no absolute priority for translation patterns to always be used first.
Response Signature
BR Oleksandr
