Call Manager and unity connection DNS
nasser2002_2005
I would like to change the DNS of the Publisher CUCM & CUC Since the DNS unreachable.( I'll Using Public DNS)
My main concern is,  do I need new Licenses and what kind of Licenses do i need?  ( i have 45 CUWL standers available )
and if there is downtime on all node on the server?
2 Accepted Solutions
Your licenses are on PLM, DNS changes will not affect them.
java
if this helps, please rate
Most likely because DNS resolution isn't working now.
8 Replies 8
Jaime Valencia
That depends on the versions you're using as licensing changes depending on the version.
java
System version: 10.5.2.12901-1
java
Thank you.
Do I need to reboot the server after the change?
Do I need to change the DNS after hour to avoid the downtime?
It will just take down the NIC for a few seconds to apply the new config, you should try to do this during a maintenance window or low use of the system.
java
Yes you need to reboot the VM.
Also, the product fully expects both forward and reverse DNS resolution to work. Be sure to create the appropriate records in the new DNS servers/zone before you make the change.
I did Not Change the DNS yet. and I'm getting the following status . any idea ?
