Call Pickup on a Hunt Group - is it possible?
ccpagel
Is pickup/Gpickup supported for a line that is ringing within a Hunt Group? We are using CCM 4.0(2)a. Nothing happends when we try to pick up a ringing line that is part of the Hunt Group (the Hunt Group is set as broadcast).
Chris
holbech
If you make a CTI port with CFA to the Hunt-pilot, and then make the CTI port a member of the pickup group, it works.
Claus
