06-18-2008 07:04 AM - edited 03-13-2019 05:22 PM
Everytime I try and execute this script I get "No Active Calls" come up on my phone, even though I am in the middle of a call. I have looked at the Tomcat error logs and all I can see is:
com.cisco.jtapi.InvalidArgumentExceptionImpl: Terminal SEP000CCE73F816 is not in provider's domain.
Any idea what this means or how I find out? I have tried Google but not much luck.
06-18-2008 07:08 AM
Have you configured CCM user for JTAPI and assiociated this phone with user profile? Also it is important to enable CTI (for ccm 4.x) or to add user to Standard CTI Enabled group (for ccm 5.x and 6.x)
regards,
PK
06-18-2008 07:32 AM
I have created a read only user called ciscoipps and associated that user to both phones. I have also enabled CTI Application use for this user.
Is there something else I am missing?
06-18-2008 07:45 AM
How did you associate phones to user?
06-18-2008 07:52 AM
Call Manager (4.1.3) Administrative Page > Navigate to user "ciscoipps" > on the left hand side I click "Device Association" > Searched for "SEP000CCE73F816" > ticked the check box beside that device and then clicked update.
06-18-2008 08:19 AM
You can validate user configuration by installing TAPI client (TSP), configuring for this user and then launching dialer.exe and checking line list. You should see associated phone's lines.
regards,
PK
06-19-2008 02:21 PM
java jtrace.JTrace userid password extension1 extension2 ...
will also do the trick. extension1 would need to be on the phone you'd like to monitor
