CallManager using GateKeeper without default-technology command
calmichael
Cisco documention alludes to the idea that one can
setup a CallManager Trunk to a IOS Based GateKeeper
that does not need to use the default-technology
command "gw-type-prefix 1#* default-technology".
My attempts at getting this to work result in calls
not getting routed in either direction, though a
"show gatekeeper endpoints" shows that CallManager
did register to the GateKeeper.
Adding the "gw-type-prefix 1#* default-technology"
and the "1#" under the CCM Trunk allows this to work,
but we would like to see a configuration that does
not rely on default-technology work successfully.
Can someone who has done this successfully post a
config snippet from the GateKeeper config and from
the CallManager Trunk (GK related) settings?
anup.anand
Level 5
Level 5
From the Gatekeepers perspective, an incoming call will be routed only if it matches either one of the three conditions
1. A configured tech prefix is matched
2. There is a default tech prefix configured
3. The target address is registered as a E.164 address.
Callmanager registers with the gatekeeper using the H323-ID and not the E.164-ID.
Hence I think, you would either have to use a default tech prefix on the gatekeeper or have the Callmanager use a tech prefix to register with the gatekeeper.
