Can I use a VG200 Gateway without using a CCM
c.onate
I have a VoIP Network with a lot of 1750 and 3640 Routers, and I have a Gatekeeper too. Now I need to buy another Gateway for that I need to know if I can use a VG200 Gateway in this network like another Router (with dial-peer voice voip or with a Gatekeeper registration)
thanks
conate
mimckee
I know for sure you can use is a an h.323 gateway without callmanager. Some of the features are limited like I don't think we support connection trunk right now but that is all I can think of.
Thank you,
-Mckee
