Cat6k gateway for both voice and fax. Is it possible?????
8gsiaw
Is any one using a cat6k switch for both voice and fax (T.38) gateway in their IPT deployment. I am interested in knowing the following:
a: which protocol/s is used btw the CCM and Cat6k
b: was CM employed as a fax relay at all
c: did you use a different g/w and if so which protocol did you use
d: which fax server apps are you using
Thanks.
jbayuka
Level 5
Level 5
Yes, Cat6K 6608 blade should work for both Voice and Fax. The protocol between the CM and 6608 is MGCP
