CCM 3.3 and MLA 1.2.2
adahan
Hi, I have CCM 3.3(3) using MLA 1.2(2), i can logon with the ccmadministrator user but when trying to access the 'configur MLA parameters' or other access rights menus i have the following message:'An error occurred while the page was loading
Couldn't initialize LDAP connection Check "Directory Base" in "MLA Enterprise Parameter Configuration" page
Does anyone faced this before, please advice.
Thanks, Avi.
smalkeric
Level 6
Level 6
Check you have installed as per the below URL
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_2/admin_gd/index.htm
ALso check for the ntwdblib.dll, replace with older version from sql 7 sp4 may help.
