10-17-2005 02:30 AM - edited 03-13-2019 10:53 AM
Does ip softphone 1.3(3) work with ccm 4.0?
It does not show any lines in the "line selection" window.
When I installed it it promted for ccm version but the lates version to choose was 3.3. Is this the reason why it does not work?
10-17-2005 02:58 AM
It takes Softphone 1.3(4a) to support CCM 4.0. You can also use IP Communicator. Both are downloadable from the following link.
http://www.cisco.com/kobayashi/sw-center/sw-voice.shtml
Hope this helps.
Brandon
10-17-2005 03:54 AM
I installed 1.3(4a) but this does not help.
I must be doing something wrong.
1. I created a new device (CTI)
2. I added the device to user's controlled devices
3. I checked the box "allow using CTI" or something like that
4. I entered username and passwd in softphone
5. I entered my ccm as primary CTI manager
Does not work.
10-17-2005 04:36 AM
Did you specify username and password for TSP as in this document?
There are also some verification and troubleshooting tips towards the end.
Brandon
10-17-2005 06:20 AM
Thanks for your tip.
The problem was realy with TSP. I installed TSP 4.0 (shipped with ccm) instead of 3.0 (shipped with softphone) and this solved the issue.
