CCM 5.1 IPMA and Extension Mobility
richb1971
Level 4
Level 4
Can someone confirm if IPMA supports EM in Proxy Mode for the Assistant?
I've got none-EM users working fine and enabled the Managers to be Mobile Managers but I get a HTML page when I select Assistant Primary Service when using EM for Assistant.
richb1971
Level 4
Level 4
Sorted. Quick answer: No, not for the Assistant.
Hi Richard,
I'm looking at a similar issue with IPMA Assistants in Shared-line mode using EM and I'm guessing the same applies? Was wondering how you came to your Quick answer - had Cisco confirmed this or had you found this through testing?
Thanks Richard :-)
Suspected answer from testing-it doesn't offer to associate Assistant to a Profile (like Manager does). Got confirmation from TAC. Kinda makes sense really-Assistants would normally be fixed I guess.
Cheers
Rich
Thanks Richard :-)
