CCMe DialPeers Block 1900 Calls??
JeffG1
Level 3
Level 3
First I assume you have to use Dialpeers with CCME, there is no easier way to handle this?
Second what is the best way to block 1900 calls and such... Do I just create a Dialpeer with no port?
rnarayana
Level 5
Level 5
Yes you have to use dial peers in CME and the best way to block 900 number is under telephony-service put the following command.
telephony-service
after-hours block pattern 1 91900....... 7-24
Radhika
