10-22-2007 04:56 AM - edited 03-13-2019 04:33 PM
hi
what do i need to do forward all traffic from my router (2811) that has to do with voice to an asa5505?
10-22-2007 06:54 AM
If you have a free public IP, configure a static NAT for it on the asa. That is the simplest and safest method.
10-22-2007 11:17 PM
i dont have a free public ip,
on my router, i have a static nat translation that forwards everything that comes to my public ip inwards to my asa
10-23-2007 03:41 AM
If you can have the cme and the router talk directly without going thru the asa, it would be simpler. CME being a router does not need firewall and would see only SIP to the eternal world.
In that case you setup a static inside nat tranalstion for port 5060 to the cme:
ip nat inside source static udp
Hope this helps, please rate post if it does
10-29-2007 07:06 AM
hi.
sorry for the late reply, i have been swamped.
the cme is on the router.i bought the package
2811/ccme.
i will add the static nat translation, but to the firewall though.
Any additional info would be very much appreciated.
