Certificate issue--csr san and certificate san does not match-- error
Bar1s
Hi everybody,
We have  A.CA which is root CA(self signed), B.CA 's cert signed with A.CA and client certificate(cucm) signed with B.CA but while I try to upload certificate we are getting --csr san and certificate san does not match-- error. All host names are lowercase.
But for CMS we had same process while signing cms certificates. For root CA we conjugated two root certificate as like B.CA.cer+A.CA.cer single file.  ->> BA.cer .
#webadmin certs cms1a.key cms1a.cer BA.cer
It worked for CMS.
Retuning to the Cucm I uploaded A.cer and B.cer also conjugated BA.cer files as tomcat trust. Unfortunately I couldn't pass signing process.
Any idea guys ?
Baris
balaji.bandi
Quick question, is the CA Server reachable to from where you installing Certificate ?
BB
Hi Bajaji,
I will say yes, but not sure.
It is necessary ? CMS did not had any issue.
Baris.
Jaime Valencia
Does the certificate you got back from your CA has the same CN and SAN entries you submitted in the CSR?
java
if this helps, please rate
Sorry to occupy here for this issue. The tool that for the using certificate to sign was the problem.
However I had to compare CSR's SAN and signed certificates SAN values.
For CSR's SAN you can check csr with https://www.entrust.net/ssl-technical/csr-viewer.cfm online tool.
Signed cert you can check certificate basically double clicking if it is .cer extension.
Baris.
