Cisco CCM playback audio
jmbelin
Dear,
We are developer of a monitoring application: AppVision.
And we have a project where we need to playback calls from your CISCO CCM server records calls.
Have you an SDK/API which allows to integrate this feature in our application (Windows)?
Best regards,
Jaime Valencia
You want to ask this in the DevNet forums, they're the ones that handle SDKs/APIs
java
if this helps, please rate
Can you give me the URL of DevNet forums.
Best regards,
Cisco CCM does not record audio so it can't play back calls.
You must be using some kind of external recording server.
Cisco Mediasense or Calabrio or some other external recording solution.
Do you know what is being used?
Graham
