06-25-2018 07:37 AM - edited 03-15-2019 05:41 AM
Dear,
We are developer of a monitoring application: AppVision.
And we have a project where we need to playback calls from your CISCO CCM server records calls.
Have you an SDK/API which allows to integrate this feature in our application (Windows)?
Best regards,
06-25-2018 09:24 AM
You want to ask this in the DevNet forums, they're the ones that handle SDKs/APIs
06-29-2018 09:58 AM
06-29-2018 11:50 AM
Cisco CCM does not record audio so it can't play back calls.
You must be using some kind of external recording server.
Cisco Mediasense or Calabrio or some other external recording solution.
Do you know what is being used?
Graham
