Cisco finesse wireless headsets
zanderc9
Which wireless headsets are compatable with Cisco Finesse? I’m currently looking at a Plantronics avoyageur 4310 but not sure if it’s compatible or not?
6 Replies 6
Leo Laohoo
$200 to connect a headset to WebEx gives you a lot of good options.
It all boils down to the preference:  Over the ears, on the ears, ear buds, ANC, boom mike, wireless, etc.
Do you prefer Cisco "branded" or anything else?
There is AFAIK no such thing as a Finesse compatible headset. The headset is compatible with whatever phone device you’re using, like a desk phone or a software application like Webex, not with the overlay application like Finesse. So you should look at it from that viewpoint. What type of calling device are you using?
Response Signature
@Roger Kallberg
The OP meant WebEx.
FYI Webex not spelled with a capital e. ‘;-)’
Response Signature
How do you know that OP meant Webex when writing Finesse @Leo Laohoo?
Response Signature
Because either the OP or someone else cross-posted this thread from other forums.
The only difference between this thread is in the other forums, there is a two-way communication between the OP and other posters.  In this thread, the OP is silent.
Makes me think that this thread was not made by the OP but by someone else cross-posting.
