Cisco IP Communicator is using port 80
Soulmaker
We are using Cisco IP Communicator 8.6.1.0 and one of our Dev team are having an issue that if he wanted to access his localport:80 it is showing the web page of Cisco instead of his local IIS. Is there a way to turn off this feature for cisco without causing an issue with his softphone?
Jaime Valencia
Disable Web Access in CUCM
java
if this helps, please rate
Hi Jamie, Thanks for the comment. It is however disabled as of the moment.
