Cisco Meeting Place 8.5.2 DVD
J_Vansen_S
Level 3
Level 3
Hi all,
We just received the Cisco MP 8.5.2 DVD from the PUT.
Prod#: MP8X-AV-SVR-K9-UP
We tried to do a clean installation via VM.
However on the installation process it HANG/STUCK at:
Running install…
Running /sbin/loader
Appreciate if anyone can please advise on the possible fault
Regards: Jocelyn
Hi Jocelyn
I am facing exactly the same issue with the MP 8.5.2 shipped with the 8.6 NFR bundle.
Tried on a VM on ESX 5, tried it as well on a VM on VmWare WS8, same result.
Tried to tweak guest OS (RHEL4 x86 or RHEL5 x86) - same result.
Is it possible that the actual DVD has a corrupted image? /sbin/loader runs from DVD at that stage.
If you solved the issue, please share the solution
MR
HI
I feel this is issue with DVD only. You may contact your Cisco Sales team to get correct DVD.
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
First did you run the media check?  That will make sure the DVD is good.  Also MP 8.5.2 only runs on ESX 4.1 and not on 5.  That might be your issue.
