CM 3.2.2 & Multilevel admin problem
8gsiaw
Hi Folks,
YOUR VIEWS PLEASE!
I am currently running CM 3.2.2 in a test environment on two servers. Both have Multilevel admin installed but one of them keeps giving me problems regarding some key services NOT starting after reboot -
EventVwr
Callmanager - Error: Database connection error..
CTI - Error: SDIControlLayer for Cisco CTIManager application is attempting to connect to Database..
However, an uninstallation of CM Multilevel apps does not fix the problem except reinstallation. No amount of restarting the d/b fixes it either.
Moreover, anybody experienced starting the CM service manually always after a reboot? Any work around to starting automatically upon reboot as intended? "cm service is set to automatic start"
paul.alvarez
Level 4
Level 4
A hint that may help you: "Error database" is usually caused by host name resolution problem on the CM server. Try to edit your hosts file on both servers and this should hopefully fix the problem...
