CM interaction with H.323 Gateway issue ???
renzil
Hi ,
I have created a route pattern 9.24XXXXXX pointing to my H.323 gateway. Following are the two dial-peer created on my H.323 gateway
dial-peer voice 100 voip
preference 1
destination-pattern 5...
voice-class h323 15
session target ipv4:10.1.1.5 ( CallManager )
dtmf-relay h245-alphanumeric
dial-peer voice 4 pots ( To PSTN )
destination-pattern 9........
port 0/1/0
prefix 9
But when my IP Phone dials a local no i.e 924XXXXXX, I get a recorded message from my CM saying the call cannot go through...
Following is the debug
cc_api_call_setup_ind_common:
cisco-username=5002
----- ccCallInfo IE subfields -----
cisco-ani=5002
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=24709281
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1
Mar 11 19:08:33.481: //-1/006ADD2B0600/CCAPI/cc_api_call_setup_ind_common:
Interface=0x44F20020, Call Info(
Calling Number=5002(TON=Unknown, NPI=Unknown, Screening=User, Passed, Present
ation=Allowed),
Called Number=24709281(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subsriber Type Str=Unknown, FinalDestinationFlag=TR
UE,
Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS
E), Call Id=56
Mar 11 19:08:33.481: //-1/006ADD2B0600/CCAPI/ccCheckClipClir:
In: Calling Number=5002(TON=Unknown, NPI=Unknown, Screening=User, Passed, Pre
sentation=Allowed)
Out: Calling Number=5002(TON=Unknown, NPI=Unknown, Screening=User, Passed, Pr
esentation=Allowed)
Mar 11 19:08:33.481: //56/006ADD2B0600/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=5002(TON=Unknown, NPI=Unknown, Screening=User, Passe
d, Presentation=Allowed),
Called Number=24709281(TON=Unknown, NPI=Unknown))
Mar 11 19:08:33.481: //56/006ADD2B0600/CCAPI/cc_process_call_setup_ind:
Event=0x4509D970
Mar 11 19:08:33.481: //56/006ADD2B0600/CCAPI/ccCallSetContext:
Context=0x445470B4
Mar 11 19:08:33.485: //56/006ADD2B0600/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 56 with tag 100 to app "Default"
Mar 11 19:08:33.485: //56/006ADD2B0600/CCAPI/ccCallProceeding:
Mar 11 19:08:33.485: //56/006ADD2B0600/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Ca
use=0)
Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Mar 11 19:08:33.485: //56/006ADD2B0600/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Mar 11 19:08:33.493: //56/006ADD2B0600/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x460D4FF0, Tag=0x0, Call Id=56,
Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Where am I going wrong ????
Rgds
Renzil
Yes, but the pots peer pattern starts with a 9, so if the number does not show up from the CallManager routing with a 9 to start, it will not match the peer, and the call won't go out.
Mary Beth
6 Replies 6
jm9393
Your CallManager is stripping the 9. Remove the period from your route pattern to send the 9 to the h323 gateway.
allan.thomas
Level 8
Level 8
Could you clarify whether your local number you are dialling should be 8 or 9 digits ?
From your config the terminating router will strip the digit 9 from the called number and then append the 9 back to the front of the remaining digits due to the prefix command. So the the actual number dialed will still be 924709281.
Mary Beth
This is exactly why clarification is required as to whether local dialling requires 8 or 9 digits. If CallManager is not stripping predot in the first instance, then the dial-peer does match the destination pattern.
However, as I have highlighted previously, the terminating gateway will strip 9 leaving 24........, which will be append again with 9 by the prefix command, and dialled number will be 924........
Yes, you are right - but it looked from the debug ccapi that it was stripping the 9. It would sure be nice if you didn't have to also worry about how many digits you were really supposed to be sending, with so many different dial plans out there!
Mary Beth
Thanks guys for all that input,
Problem solved. I configured the route pattern as 924XXXXXX then the pots dial-peer as follows
port 0/1/0
I needed to have an 8 digits dial plan as its applicable here in Oman.
Rgds
Renzil
