ATTENTION: We are currently working an issue with posting. Thank you for your patience while we work on a resolution.
CME3.4 and IP Phones CP7911G
ccedric
Is CP-7911G supported on CME 3.4 or Must I upgrade it?
Ced
alessandro.dona
Level 3
Level 3
I hope this link can help:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a008055677f.html
However i think you have to upgrade.
I had a problem with 7911g and srst solved by upgrading to 4.0
Hi Alessandro,
Thanks - I try this. I will upgrade CCME in 4.0.3 et IOS 12.4(4)xc4a version.
I just must extract all zip files to my flash to replace old version? That's all?
Ced
You have to change the release and be sure the router comes up with the new release.
Add the command "load " under thelephony-service
and tftp-server flash under global conf mode.
If you have additional files(such as localization files) download the right files for your new release(and store them in the flash).
It is just a little bit boring.
