03-27-2007 12:06 AM - edited 03-13-2019 04:01 PM
Is CP-7911G supported on CME 3.4 or Must I upgrade it?
Ced
03-27-2007 03:19 AM
I hope this link can help:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_installation_guide09186a008055677f.html
However i think you have to upgrade.
I had a problem with 7911g and srst solved by upgrading to 4.0
03-27-2007 03:31 AM
Hi Alessandro,
Thanks - I try this. I will upgrade CCME in 4.0.3 et IOS 12.4(4)xc4a version.
I just must extract all zip files to my flash to replace old version? That's all?
Ced
03-27-2007 03:42 AM
You have to change the release and be sure the router comes up with the new release.
Add the command "load " under thelephony-service
and tftp-server flash under global conf mode.
If you have additional files(such as localization files) download the right files for your new release(and store them in the flash).
It is just a little bit boring.
