command ds0-group vs pri-group and E1 ISDN PRI vs E1 CCS
JERRI -
hi all,
When I using E1 ISDN PRI on my gateway, what should i use in controller interface
ds0-group
or
 pri-group ?
What I know, that for ds0-group, is for E1 / T1 CAS, pri-group is for E1 /T1 isdn pri.
is it correct?
and, are it the same for E1 ISDN PRI  with E1 CCS?
thanks,
Jerri
2 Accepted Solutions
Ayodeji Okanlawon
Yes Jerri, you are correct. Use pri-group for E1/T1 ISDN.
Please rate all useful posts
CCS is called common channel signalling. This is what ISDN uses. It uses a single channel called the D channel to carry the signalling for the whole circuit. CAS (channel associated signalling) carries signalling information in the bearer channel.
So yes E1 ISDN PRI uses CCS
6 Replies 6
Ayodeji Okanlawon
Hi Ayodeji,
Thanks for the respond.
Hi Ayodeji,
One more question,
why in E1 CAS,
the command for timeslot is
ds0-group timeslot  1-15,17-31 type xxx?
as we know that, CAS, using robbed bit signaling.
why not
ds0-group timeslot  1-31 type xxx for the CAS?
and,
as far as I know, timeslot 1st for framing, why timeslot 1st, included in
ds0-group command
Jerri
Jerri,
E1 CAS is not my forte! I know almost nothing about it. You can check online to see if you find answers to this..
Hi Ayodeji,
One more question,
why in E1 CAS,
why not / what is the different between
ds0-group timeslot  1-31 type xxx for the E1 CAS?
and,
ds0-group command
Jerri
