Complex destination-pattern, only for Pro
I need Pro to answer me how can I build destination-pattern for those numbers. I cannot find the solution. I think that is impossible. Final solution is to write 10 destination pattern.
50
100
200
3000
40000
53
113
213
3013
40013
Thanks in advance
With regards
Dubravko
j.ayres
I think it can be done in two:
destination-pattern 5[0,3] and
destination-pattern [1,2,30,400][00,13]
Hope this helps.
Justin
j.ayres
Hope this helps.
Justin
Thanks Justin for help
Dubravko
