06-26-2007 02:18 AM - edited 03-13-2019 04:15 PM
I have a 2811 with PVCM2-16 and I want to configure for voice termination (VIC2-2BRI-NT/TE) and transcoding (SIP G729 to PSTN G.911)
How can I configure DSPs for voice termination and transcoding?. I don't use CCM.
"running-config" and "show voice dsp detail":
isdn switch-type basic-net3
isdn tei-negotiation first-call
voice-card 0
no dspfarm
dsp services dspfarm
voice rtp send-recv
voice service pots
voice service voip
sip
no call service stop
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729br8
interface FastEthernet0/0
description LAN maqueta
ip address 192.168.1.253 255.255.255.0
duplex full
speed 100
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
interface BRI0/0/1
no ip address
shutdown
ip route 0.0.0.0 0.0.0.0 192.168.1.254
no ip http server
ip http access-class 23
control-plane
voice-port 0/0/0
voice-port 0/0/1
dial-peer voice 1 pots
description *** Llamadas con BRI ***
numbering-type national
service session
destination-pattern 88T
direct-inward-dial
port 0/0/0
dial-peer voice 2 voip
description ** LLamadas entrantes desde PSTN hacia SIP XXX
service session
destination-pattern 77T
voice-class codec 1
session protocol sipv2
session target dnsxxxxxxxxx
session transport udp
gateway
timer receive-rtp 1200
sip-ua
nat symmetric role passive
sip-server dns:xxxxxxxxxxxx
*DSP VOICE CHANNELS*
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 02 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 03 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 04 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 05 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 06 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 07 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 08 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 09 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 10 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 11 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 12 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 13 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 14 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 15 None 4.4.24 idle idle 0 0 0 0/0
C5510 001 16 None 4.4.24 idle idle 0 0 0 0/0
*DSP SIGNALING CHANNELS*
------------------------END OF FLEX VOICE CARD 0 ----------------------------
Please advise.
Solved! Go to Solution.
06-27-2007 01:37 AM
Hola,
transcoding is when you need to change codec on a RTP session to support e.g. voicemail, conferencing. This happens trasparently, like:
[ip phone/g729]----[transcoding]----[voice mail/g711]
You can terminate G.729 or any other codec, to PSTN, analog or digital, without need for transcoding. This happens since cisco has invented VoIP about 10 years ago :)
Now since you have a cisco router, wanted to let you know, on it you can configure "CME" feature and it will support all the IP phones, cisco or other brand, with features same or superior to the popular sip proxies. And does not require external hardware.
Thanks for the nice rating and good luck!
06-26-2007 04:21 AM
What are you using that requires transcoding? Please include a complete network diagram.
Are the basic calls via ISDN BRI working OK ?
06-26-2007 07:03 AM
Hi p.bevilacqua and sorry for my poor information,
the network diagram is the next:
IP Phone (G.729) -- SIP proxy (G.729) -- Gateway (2811 + PVDM2-16) -- PTSN (G.711) -- analog phone.
I think the Gateway should implement "voice termination" and "transcoding G.729 - G.711) functions, isn't it?
Now, the basic calls via ISDN BRI are working ok, because IP Phones and SIP proxy are configured with G.711 codecs, but I don't know if DPSs are used in this calls. (IP Phone G.711 -- Gateway (BRI) -- PSTN G.711)
I don't know how DSPs are used, when you want to make voice termination and transcodig. Remember that I haven`t a Cisco Call Manager
thank you for your help,
06-26-2007 07:51 AM
Hola,
You don't need transcoding for this. Just make sure that in the incoming DP voip, you either configure G.729, or a voice class that list both G.711 and G.729, so it will work with both codecs without further modifications.
Let us know if it works.
hope this helps, please rate post if it does!
06-27-2007 12:34 AM
Hi again p.bevilacqua,
sorry for my ignorance about this voice configurations, but I don't know if I understand you...
If I call from IPphone (G.729) to PSTN-phone (G.711) why don't the router do transcoding functions?
The article Cisco Enhanced Conferencing and Transcoding for VoiceGateway Routers (http://www.cisco.com/en/US/partner/products/ps5854/products_qanda_item0900aecd8016c2c7.shtml) says this:
Q. Can any other call agents other than Cisco CallManager use the Cisco Enhanced Conferencing and Transcoding for Voice Gateway Routers feature?
A. Not at this time.
Muchas gracias por tu ayuda (from Spain)
06-27-2007 01:37 AM
Hola,
06-27-2007 01:56 AM
Thank you very much
I think today I've learned a little bit from VoIP :)
