Configuring a SIP to SIP Gateway
jbroderick
Contributor
Contributor
I am trying to configure a SIP to SIP gateway so I can get a SIP trunk through the firewall. Do I use Dial Peers to direct the traffic? The document gives me basics but not specifics.
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Yes you use dial-peers voip for both inbound and outbound. Generally speaking, you will have "codec transparent" set on these.
You will need and IP-to-IP image to do that, filename ends in _isv, but you probably knew that already.
Does it helps? please rate post if it does!
No, I didn't know this. I am using a 2821 router running this image: c2800nm-advipservicesk9-mz.124-11.T1.bin. Will this work?
No I don't think it will work. Anyway, another needed piece of configuration is:
voice service voip
allow-connections sip to sip
Then, to see how things are going, "term mon" and "debug ccsip message" when placing a call.
Thank you for the nice rating and good luck!
Recognize Your Peers
